Map Plot Settings
Use Map Plots to display geographic data, where you have longitudes and latitudes associated with individual data points. These plots clearly show data correlations and clustering that is geographic in nature.
In a Map Plot, the visualization expects Latitude and Longitude measures to be associated. It will then retrieve from the selected map tile provider with the appropriate background map to display under the data points. This background map is constructed by retrieving individual map tiles at set zoom levels.
As the background map is provided automatically, it relies on:
- A range of supplied longitudes & latitudes to provide a bounding area
- An active Internet connection to retrieve the map tile images
Panopticon ships with a number of cross reference datasets to determine the appropriate latitude/longitude for datasets. These have been provided through subsets of the data available at GeoNames.org. ( http://www.geonames.org )
More detailed geo-coding data is available from this website, and many others.
The map plot settings pane is displayed after clicking the Options
button.
| Setting | Description |
Map Provider |
Determines which Map Provider should be used for providing Map tiles. Initially only a single map provider is defined, but more can be added by modifying |
Show Shapes |
Determines whether shapes will be displayed. Turned on by default. |
Min Radius |
The minimum radius in pixels of the data point. |
Max Radius |
The maximum radius in pixels of the scatter point. |
Show Line |
Determines whether to plot lines between two positions on the map. Enables the Line, Line Color, and Line Color properties. |
Line |
Two ways to plot the line:
Line Width |
Width of the plot line. |
Line Color |
Color of the plot line:
Show Arrows |
Determines whether to display arrows to indicate where lines start and end. |
Arrow Offset |
Where the arrows will be positioned in the lines
Show Labels |
Determines whether labels will be displayed. |
Label Mode |
Enabled when Show Labels is checked. This property determines how data point labels are shown. Values can be:
Shape |
The shape of the scatter point. This can be:
Show Borders |
Determines whether a border is drawn around each data point. |
Keep Zoom and Pan |
Determines whether the saved zoom and pan state on data refresh and initial dashboard load are kept. |
Show Zoom Levels |
Determines whether a zoom level indicator should be displayed on the Map Plot. |
Max Zoom Level |
The maximum zoom to be applied when there is a single data point, rather than a collection, so a latitude / longitude bounding box cannot be established. |
