Latitude and Longitude Variables Configuration
Longitude and Latitude variables are available in the Map Plot visualization. These coordinates are used to locate a place on Earth’s surface.
The configuration pane for Lat and Long Variables is the same as for the Size variable.
NOTE: Default aggregation for the Latitude and Longitude variables are:
  • Mean for numeric columns.
  • Calculation for calculated columns.
  • External if data table contains external aggregates for the column.
(c) 2013-2025 Altair Engineering Inc. All Rights Reserved.
