Hiding or Displaying Columns in the Table Visualization
Table visual members can be hidden and displayed again. You can right-click on a column name and select Show/Hide Columns.
A column control pop-up displays. By default, the Select All option is enabled.
Select the checkboxes of the columns that will be displayed.
You can also enter a value on the Filter box to search for certain columns. All the search results are displayed and the Select All Search Results option is enabled.
To clear the Search field, click
Click Set Only Selected to apply the filter to the visualizations in the dashboard.
