Free Text
Free Text is the default selection mode when the text filter column has more than 30 values.
On the dashboard, this mode shows a free text entry box.
When entering a value, matches are displayed allowing you to pick one from the list. You can do so by double-clicking on it.
For Free Text with Substring default wildcard, entering Bank for this example displays values in the suggestion list that contain Bank.
For Free Text with Prefix default wildcard, entering Bank for this example displays values in the suggestion list that begin with Bank.
For Free Text with None default wildcard, entering Bank for this example displays values in the suggestion list that begin with Bank. Also, there are no automatically appended wildcards on the dashboard.
The number of options/suggestions on the drop-down will depend on the Suggestion List Max Size. Default is 10.
You can click  to clear the field.
(c) 2013-2025 Altair Engineering Inc. All Rights Reserved.
