Define the Color Palettes Settings of a Theme
When you define the settings of the color palettes, you can manage, import, or export Text, Sequential, and Diverging color palettes.
- To select the Diverging, Sequential, and Text color palettes to use within the workbooks, click the Color Palettes tab.
NOTE: For more information on how to create, modify, duplicate, or delete Single, Sign, Text, Sequential, or Diverging Palettes, refer to the Color Palettes sections.
- Select the checkboxes of the provided color palettes that will be included for each category.
- Click the radio button of the preferred Default color palette for each category.
- To upload color palettes, click
. The Upload Color Palette dialog displays.
- To export color palettes, you can either:
- Drag the file from your desktop and drop on the dialog, or
- Click Choose color palettes file to upload and then browse and select one on the
Open dialog that displays.
The name of the color palette is displayed on the uploaded color palette area and in the Name box.
You can opt to rename the uploaded color palette.
- To replace the color palettes, select the Replace Color Palettes checkbox.
- Click
A notification displays once the color palettes file is uploaded.
- To export color palettes:
- Click
for all color palettes. The ColorPalettes.excp file is exported. - Click the Export Palette
icon of a color palette. The <ColorPaletteName>.excp file is exported.
- Click
- Proceed to the General Colors tab to specify the general colors of the theme.
