Database Data Sources
Connector for Apache Cassandra
The Apache Cassandra connector allows connection to Apache and Datastax Cassandra instances, by executing a pre-defined CQL query, and retrieving the resulting data.
- Enter the following information:
Property Description Host
Apache Cassandra host address.
Port
Apache Cassandra host port. Default is 9042.
Local Datacenter
The local datacenter of Cassandra contact points.
KeySpace
Namespace that defines data replication in nodes.
User Id
The username used to connect to the Apache Cassandra service.
Password
The password used to connect to the Apache Cassandra service.
Page Size
The number of rows that will be retrieved per page from Cassandra. Default value is 1000.
NOTE: This property helps optimize performance and memory usage during large data loads.
- Select whether the parameters should be automatically enclosed in quotes, by checking the Enclose parameters in quotes box.
- Enter the CQL Query, which can contain parameters in a similar manner to the database connector.
- Date/Time values of output data and Date/Time inputs, where supported, are by default unchanged.
