Creating a New Text Color Palette In the Workbook
The configuration pane for the Color variable changes depending on the column data type.
When a text column is added to the Color variable, the configuration pane displays the color associated with each categorical item, as specified with a default color palette (e.g., Twenty Eight Colors).
  1. On the Text section, click the Add Palette   icon.
    The New Text Palette dialog displays.
  2. Enter the Title then click  .
  3.  Select the Number of Colors in the drop-down list. Default is 28 colors.
    The Other list is updated accordingly.
  4. To set the colors, you can do one of the following:
    • Click the Color box to display the Color dialog and set the Hex color code, RGB, or HSL value
    • Enter the Hex color code
    • Enter the HTML color name
  5. Click   .
    The new text color palette is added in the list. Note that it is already included and can be modified, duplicated, and deleted.
(c) 2013-2024 Altair Engineering Inc. All Rights Reserved.
