Creating a New Sign Color Palette In the Workbook
The Sign color palette is used to signify the positive or negative values in numeric visual members.
- On the Sign section, click the Add Palette
icon.
The New Sign Palette dialog displays.
- Enter the Title then click
- To set the Positive Color (default is Gray) and the Negative Color (default is Red), you can do one of the following:
- Click the Color box to display the Color dialog and set the Hex color code, RGB, or HSL value
- Enter the Hex color code
- Enter the HTML color name
- Click
The new Sign color palette is added in the list. Note that it is already included and can be modified, duplicated, and deleted.
