Creating a New Sign Color Palette
The Sign color palette is used to signify the positive or negative values in numeric visual members.
  1. On the Sign section, click the Add Palette   icon.
    The Next Sign Palette dialog displays.
  2. Enter the Title then click  .
  3. To set the Positive Color (default is Gray) and the Negative Color (default is Red), you can do one of the following:
    • Click the Color box to display the Color dialog and set the Hex color code, RGB, or HSL value
    • Enter the Hex color code
    • Enter the HTML color name
  4. Click   .
    The new Sign color palette is added to the list (e.g., Red-Green). Note that it is already included and can be modified, duplicated, and deleted.
(c) 2013-2024 Altair Engineering Inc. All Rights Reserved.
