Creating a New Shape Palette in the Workbook
- Click Add Palette
A new shape palette displays (i.e., ShapePalette.0).
- Click ShapePalette.<Number>.
The section expands to allow its definition.
- Enter the shape palette Title and click
. - To make this shape palette the default for the workbook theme, tap the Default Palette slider to turn it on.
NOTE: The default shape palette can not be deleted.
- To add the shapes, click
You can either:
- Click on a shape.
- Click
. Select one or more SVG files in the Open dialog box that displays.
The added shapes are displayed.
To delete a shape, click it’s corresponding Delete
icon. - Select the Default Shape in the drop-down list.
- Click the Save
icon on the toolbar to save the changes.
The new shape palette is available on the Shape Palette drop-down list in the Shape variable when the workbook theme, where it is added, is used (i.e., Light).
