Creating a Duplicate of a Calculated Column
Make a copy of a generated calculated column and modify it to create a new one.
On the Data Sources Settings, click Calculated Columns to display the available user-defined columns.
- Click the Duplicate
button of a Calculated Column.
A copy of the duplicated calculated column is displayed on the Calculated Column pane.
- You can opt to modify the properties of the duplicate column.
- Click
. The duplicate calculated column is added and displayed in the Data Preview.
