Constant Parameters
Actions support specifying constant (non data-driven) values for parameters inside the action. Set the Value Source of the parameter to $Constant and specify any text value.
The constant value will then always be used for that parameter whenever the action is executed.
In the above example, whenever Select Stock action is executed, the Ticker parameter will receive the value LOW.
(c) 2013-2025 Altair Engineering Inc. All Rights Reserved.
