Database Data Sources
Connector for Apache Cassandra
The Apache Cassandra connector allows connection to Apache and Datastax Cassandra instances, by executing a pre-defined CQL query, and retrieving the resulting data.
  1. Enter the following information:
    Property Description
    Host
    Apache Cassandra host address.
    Port
    Apache Cassandra host port. Default is 9042.
    Local Datacenter
    The local datacenter of Cassandra contact points.
    KeySpace
    Namespace that defines data replication in nodes.
    User Id
    The username used to connect to the Apache Cassandra service.
    Password
    The password used to connect to the Apache Cassandra service.
  2. Select whether the parameters should be automatically enclosed in quotes, by checking the Enclose parameters in quotes box.
  3.  Enter the CQL Query, which can contain parameters in a similar manner to the database connector.
  4. Date/Time values of output data and Date/Time inputs, where supported, are by default unchanged.
(c) 2013-2024 Altair Engineering Inc. All Rights Reserved.
