Connecting to a Data Source in the Workbook Internal Data Table Editor
- Select a data source group tab in the Connectors pane then select a data source.
The Connector Settings pane displays (e.g., Altair AI Hub).
- You can opt to modify the Name of the data source then click
. - Define the data source properties or options in the connector.
- Set the row limit of the data set, if required.
- Tap the Preview Selected Data Source slider to turn it on.
- Select one of the following:
for static connectors, or-
for streaming connectors.
