Calculation Aggregation
Calculation aggregation is sometimes needed with calculated columns.
If the Calculation aggregate is used, any calculated columns will be re-executed up the hierarchy, so that the calculation is done on group-level aggregates instead of row-level values. Furthermore, each term in the calculation will be summed by default, but this can be controlled if a different aggregation is needed.
The aggregation applied to each column included in the calculation expression can be specified using the following syntax:
[term:aggregate]
For example:
[exposure:sum]/[risklimit:mean]
[exposure]/[risklimit:mean] also has the same result since no aggregation specified defaults to sum
NOTE: Most of the Panopticon aggregation methods are supported, except those that involve more than one column.
You can specify any of the following functions:
- abs
- abssum
- count
- countdistinct
- countnonzero
- harmonicmean
- level
- max
- mean
- min
- neg
- percentofweightparent
- percentoftotalreference
- pos
- product
- siblingrank
- stdev
- stdevp
- sum
