Altair AI Hub Connector Settings in the Panopticon.properties File
The following properties are required for the endpoint listing feature of the Altair AI Hub connector. In addition to these, you are also asked to provide OFFLINE_TOKEN inside the connector UI, when you try and click Fetch Endpoints for the first time, for subsequent calls, OFFLINE_TOKEN is cached. Correct values for these properties including OFFLINE_TOKEN can be found at token generator. The Token Generator is accessible by navigating to https://your-platform-deployment/get-token/.
Property |
Altair AI Hub Connector Endpoint Listing |
Attribute |
connector.aihub.client.id |
Description |
Application (client) ID assigned at the Altair AI Hub. |
Default Value |
Property |
Attribute |
connector.aihub.client.secret |
Description |
Your application’s client secret created at the Altair AI Hub. |
Default Value |
Property |
Attribute |
connector.aihub.grant_type |
Description |
The grant type to be used to make token request. |
Default Value |
refresh_token |
Property |
Attribute |
connector.aihub.url |
Description |
The root URL to Altair AI Hub, where token and endpoint request are sent. |
Default Value |
