Adding a Tabbed Panel
Allows you to add a tabbed panel within a dashboard where visuals can be assigned to each tab.
- After double-clicking or drawing a rectangle on the dashboard canvas, scroll to the General section of the Part Types pane and select Tab Panel
The tabbed panel is displayed on the dashboard with the first tab (i.e., New Tab 1).
- You can opt to define the name or title of the tab by doing one of the following:
- Double-click on the tab and enter the name or title, or
- Right-click on the tab and select Rename. Then enter the name or title.
- Add visualizations on the panel as needed.
- Click Add Tab
to add a new tab.
- Repeat steps 2 to 4 to define and add more tabbed panels.
- You can also opt to do any of the following:
- Rearrange the order of the tabs.
- Delete a tab by right-clicking on it and selecting Remove in the context menu.
- To copy other dashboard parts into the tab panel, do one of the following:
- Select the dashboard part and click Copy
on the toolbar, then select the tab panel and click Paste
on the toolbar, or - Select the dashboard part and click Ctrl + C, then select the tab panel and click Ctrl + V.
- Click the Save
icon on the toolbar to save the changes.
