Adding Global Parameters
Follow the steps below to add global parameters with a Designer role.
  1. On the Parameters tab, click New Parameter   of a global folder (root or subfolder).
    A new parameter entry displays.
  2. Enter a unique Name for the new parameter.
  3. Select the Type: Text, Numeric, or Time.
  4. Enter the Default Value.
    NOTE:
    • You can enter several default values, separated by a comma.
    • Single quotes on parameter value/s are removed when saving global parameters.
    • For the Time type, the following formats for the default value are accepted:
      • "yyyy-MM-dd"
      • "yyyy-MM-ddTHH:mm:ss"
      • "yyyy-MM-ddTHH:mm:ss.SSS"
  5. Tap the Encrypted slider to encrypt the value, if required.
    NOTE: Encryption is only supported for text parameters.
  6. Click  . The new parameter is added to the list.
    Global parameters added in the parent/root folder are inherited by the corresponding subfolders.
(c) 2013-2025 Altair Engineering Inc. All Rights Reserved.
