3D Scatter Plot Settings
3D Scatter Plots are a 3D perspective version of the 2D Scatter Plot. They provide a clearer understanding of physical shapes in a 3D space. The Scatter Plot 3D is made up of a series of points where each point has X Position, Y Position and Z Position.
In addition, items can be sized by numeric data values and colored by numeric or text data values. Items can also be shown as different shapes – either standard shapes available in Panopticon or custom shapes that you add to a custom shape palette.
The 3D Scatter Plot settings pane is displayed after clicking the Options
button.
| Setting | Description |
Show Borders |
Determines whether borders are visible around each scatter point. |
Show Labels |
Determines whether labels will be displayed. If enabled, select how scatter point labels are shown:
Min Radius |
The minimum radius in pixels of the scatter point. |
Max Radius |
The maximum radius in pixels of the scatter point. |
Show Axes |
Determines whether axes are displayed. |
Show Axes Titles |
Determines whether axes titles are displayed. |
Show Ground Plane |
Determines whether the ground plane is displayed. |
