Viewing Project Information
Under Project Information heading you can view, copy, and print the information contained in the current project. It also provides access to the Audit Trail.
NOTE: The contents of the Project window vary, as they are determined by the contents of the current project.
The Project Information section displays information such as:
Author: Displays the author of the current project.
Description: Displays the current description of the project file.
Current State: Displays the currently active view, and the current summary, filter or sort (if any).
Model: Displays the path of the project's model file.
Report: Displays the path of the project's report file.
Project Exports: Displays information about the project's export(s), such as the name and export location of the export file, whether a filter is assigned to the table, etc.
Audit Trail: Displays the audit trail for the current project.
To print the information contained in the current project, use the Print icon in the upper-right corner of the Project Information section.
