Tableau Server screen
This screen displays when you specify .hyper as the file extension in the Output File screen of the Export Wizard and then click Next. Use this screen to specify the settings for publishing to Tableau Server.
The Tableau Server screen includes the following options:
  • Publish to Tableau Server: Select this option to display the Tableau Server settings.
  • Data Source Name: The name of the data source on the Tableau Server.
  • Path to TABCMD: The route to the executable file of the TableauServerTabcmd application.
  • Server Address: The address of the Tableau Server.
  • Username: The login name to the Tableau Server.
  • Use Password File: Select this option to use a password file in .txt format.
  • Password: The password to the Tableau Server (NOTE: If the Use Password File option is selected, you need to specify the path to the password file).
  • Proxy Address: The address of the proxy server in HOST:PORT format.
  • Publish Type: Allows to specify an action for the data source:
    • Overwrite data source: Overwrites the data source with the data from the export table (NOTE: Date modified is changed);
    • Replace data: Replaces the data in the data source with the data from the export table (NOTE: Date modified is not changed);
    • Append data: Adds data from the export table to the end of the data source table.
  • Back: Displays the Output File screen.
  • Finish: Saves the current export settings and closes the Export Wizard.
  • Cancel: Cancels the export operation and closes the Export Wizard.
