Running a Log Clearance Task
When you finish configuring a log clearance task, you can run it to perform the specified action, in the same way as you assign a maintenance task.
To run a log clearance task
  1. Configure a maintenance process.
NOTE: If the desired maintenance process already exists, skip down to step 2.
  1. Assign the log clearance task to the maintenance process, in the same way as you assign a maintenance task.
  2. Run the maintenance process. When the process is executed, the tasks assigned to it will be run as well.
© 2024 Altair Engineering Inc. All Rights Reserved.
