Project Inputs via Manifest
To specify values for Text Inputs using a manifest, construct the manifest XML as in the following example:
<manifest process="Process">
<inputs>
<item name="Input">
<uri>file:Input path</uri>
</item>
</inputs>
</manifest>
NOTE: JSON schema may also be used for manifests. An example is shown below.
"process": "Process",
"inputs": [
"name": "Input",
"uri": "Input path"
To specify values for Database Inputs using a manifest, construct the manifest XML as in the following example:
<inputs>
<item name="Input">
<db_import excel_column_names_row="true or false" replace_nulls="true or false">
<data_source>data source</data_source>
<table_name>table name</table_name>
<password>password</password>
<apply_filter>filters</apply_filter>
</db_import>
</item>
</inputs>
</manifest>
NOTE: JSON schema may also be used for this purpose. An example is shown below.
"inputs": [
"name": "Input",
"db_import": {
"data_source": "data source",
"table_name": "table name",
"password": "password",
"replace_nulls": "true or false",
"excel_column_names_row": "true or false",
"apply_filter": "[column name]=value"
