Process Designer Scripting API
We have provided a short collection of script fragments to take a look at and copy and paste to serve as starting points or fragments of your own scripts.
The Visual Process Designer Scripting API expose the following members:
AddEvent: Adds any text to the log (for informational or auditing purposes).
AddInput: Adds an input item to the process.
AddOutput: Adds an output item to the items for the specified export.
AddPassword: Adds a script password.
AddRuntimeFieldValue: Sets the value for a runtime field. This value will be used, if called for, by subsequent exports.
AddVariable: Adds a variable to the script.
ClearPasswords: Clears all script passwords.
ClearRuntimeFieldValues: Clears values for runtime fields.
ExpandMacros: Expands macros in a given string, in the context of the entire log.
GetEvents: Gets the list of events for the log item specified by name.
GetExports: Gets the list of process export names.
GetInputs: Gets the list of input items.
GetOutputRowCount: Gets the row count of Report, Table, Summary, or DataPrep export by export element name; by export element name and location; or by export element name, location, and table name.
GetOutputs: Gets the list of output items for a process.
GetOutputs (string): Gets the list of output items for a specified process export.
GetOutputTableNames: Gets the table names of Report, Table, Summary, or DataPrep export by location.
GetPassword: Gets the list of script passwords.
GetProcessName: Returns the name of the process.
GetRuntimeFieldValue: Returns the current value, if any, for a given runtime field name.
GetTrackingId: Gets the tracking ID of the current log.
GetVariable: Gets the list of script variables.
HasPassword: Returns “true” if the password as added using the AddPassword method
HasRuntimeFieldValue: Returns true if a value has already been set for a given runtime field name.
RiseAlert: Rise process or global alert by name with a specified message.
Here are some specific examples.
API.AddInput Method
Syntax: void AddInput(string fileName)
Parameters:
fileName
Type: System.String
Path to the input file.
API.AddOutput Method
Syntax: void AddOutput(string exportName, string location)
Parameters:
exportName
Type: System.String
Name of process export.
location
Type: System.String
Path to the output file.
API.AddRuntimeFieldValue Method
Syntax: void AddRuntimeFieldValue(string fieldName, string fieldValue)
Parameters:
fieldName
Type: System.String
Name of runtime field.
fieldValue
Type: System.String
Value of runtime field.
API.ClearRuntimeFieldValues Method
Syntax: void ClearRuntimeFieldValues()
API.GetExports Method
Syntax: IList<string> GetExports()
Return Value:
Type: StringCollection
A StringCollection containing the process export names.
API.GetInputs Method
Syntax: IList<string> GetInputs()
Return Value:
A StringCollection containing the process inputs.
API.GetProcessName Method
Syntax: string GetProcessName()
Return Value:
Type: String
The name of the process.
API.GetOutputs Method
Syntax: IList<string> GetOutputs()
Return Value:
A StringCollection containing the process outputs.
Syntax: IList<string> GetOutputs(string exportName)
Parameters:
exportName
Type: System.String
Return Value:
A StringCollection containing the outputs of the process export.
API.GetRuntimeFieldValue Method
Syntax: string GetRuntimeFieldValue(string fieldName)
Parameters:
fieldname
Type: System.String
Return Value:
Type: String
Value for the specified runtime field or empty string.
API.HasRuntimeFieldValue Method
Syntax: bool HasRuntimeFieldValue(string fieldName)
Parameters:
fieldname
Type: System.String
Return Value:
Type: Boolead
True if this field has a value already set
