Editing a Report Instance
To edit a report description
On the Navigation Tree, click Report Warehouse, then click Document Management and select Document Types.
On the Document Types page, do one of the following:
Click the name of the document type you want to edit a report for.
Select the document type, by clicking anywhere on the row, and then click
The Document Type page appears.
Select the Report Instances tab at the top of the page.
Do one of the following:
Click the name of the report file you want to edit.
Select the report file, by clicking anywhere on the row, and then click
The Report Instance page appears.
Make the necessary changes (change the date, or select the Blocked check box), and click Save.
The system saves the modified report description to the database and displays the updated Report Instances page, if the operation is completed successfully.
