Editing a Change List
Change Lists can be edited via the Change Lists page.
To edit a change list
  1. On the Navigation Tree, click Server Library and select Change Lists.
  2. Select the Change List you want to edit on the Change Lists page:
Click the name of the change list you want to edit or click anywhere on the row, and then click.
  1. Make the necessary changes. For details about how to change list parameters refer to Adding a Change List topic.
  2. To the changes, click the Save button.
    The system saves the modified change list to the database and displays the updated Change Lists page, if the operation is completed successfully.
To view and restore change list revisions
You can view or restore change list revisions any time using the Revisions tab.
  1. On the Navigation Tree, click Server Library, and select Change Lists.
  2. Click the name of the change list file you want to restore a revision for or click anywhere on its row, and then click .
  3. On the displayed page, select the Revisions tab.
  4. Choose the revision to be restored, and then click the  corresponding Restore icon.
  5. A prompt displays. Click Ok to proceed.
The restored revision occupies the latest entry in the list of revisions in the Revisions tab.
To delete a change list revision
  2. Click the name of the change list file you want to delete a revision for or click anywhere on its row, and then click .
  4. Choose which revision to delete by clicking anywhere on its row, and then click the Delete button  found at the end of the row or on the top left-hand side of the Revisions page.
  5. A prompt displays. Click Delete to proceed with the deletion.
To assign change list to user groups, roles, or users
  2. Select the model you want to edit on the Change Lists page. Click the name of the change list you want to edit or click anywhere on the row, and then click .
  3. Click the Rights tab. For more information, see Assigning Change List Access Rights.
© 2024 Altair Engineering Inc. All Rights Reserved.
