Dropping Pre-Mined Data
The Drop Pre-Mined Data maintenance task allows to remove pre-mined data from the MS database. The archived documents become non pre-mined after running the task.
To drop pre-mined data
  1. On the Navigation Tree, click Report Warehouse, then click Maintenance and select Maintenance Tasks.
  2. Click clip0002 on the Maintenance Tasks page. The Maintenance Task page appears.
  3. Configure a maintenance task, making sure to select the Drop Pre-Mined Data option from the Task Type drop-down list.
  4. Click Save.
  5. On the Navigation Tree, click Report Warehouse, then click Maintenance and select Maintenance Processes.
  6. Click clip0002 on the Maintenance Processes page. The Maintenance Process page appears.
  7. Configure a maintenance process, making sure to assign the maintenance task you just created to it.
  8. Schedule the process to run, or run it manually by clicking Run Now on the Maintenance Process page.
When the process is executed, the maintenance task runs and the pre-mined data is removed.
© 2024 Altair Engineering Inc. All Rights Reserved.
