Deleting a Template
You can delete a template from the system via the Templates page.
To delete a template from the list
On the Navigation Tree, click Server Library and select Templates.
Click
at the end of the row with the template you want to delete. A dialog box appears.
Click Delete to delete the template from the list.
NOTE: If a template has the Locked status (), it cannot be deleted. First unlock the template and then try again.
