Deleting a Process
You can delete any process on the Processes page.
NOTE: When you delete a process, all of its associated jobs on the Jobs page are also deleted.
To delete a process
  1. On the Navigation Tree, click Automator and select Standard Processes.
  2. Click Delete end row at the end of the row with the process you want to delete. A dialog box appears.
  3. Click Delete to remove the process from the list.
    The process is removed from the Processes page, and its associated jobs are removed from the Jobs page.
NOTE: When deleting a standard process that uses a model or a project in the Server Library, a dialog box appears and gives the option to Delete dependencies. Clicking the Delete dependencies button removes the associated model or project from the Server Library. Clicking Cancel deletes the process only and not the associated model or project. The Delete dependencies option is not available when the model or project is used by more than one process.
