Default Job Log Disposition
Job log disposition settings specify what is to be done with the job log after a job is run, and under what circumstances the specified disposition will occur. Job log disposition settings can be specified on a process basis or you can specify default job log disposition settings, which will apply to all job logs.
NOTE: After you specify job log disposition settings for a process, be sure to specify a schedule for the Custodian and enable it, as the Custodian is responsible for implementing the disposition settings. If you do not specify a schedule for the Custodian, the disposition settings will not be implemented.
To specify a default job log disposition
  1. On the Navigation Tree, click System Settings,  and then select System Preferences.
  2. A the top of the page under Automator Settings, select the Default Job Log Disposition tab
  3. Select one of the following Job Log Disposition actions:
    • Leave: Leaves the job log in its current location and with its current name.
    • Remove: Removes the job log.
    • Move: Moves the job log to the location you specify.
    • You can either enter the destination folder path in the text box or select the folder by clicking the Browse button. The Named Paths dialog box will appear.
    • From the Named Paths list, select the appropriate named path.
    • Select the folder from the list of displayed in the Named Path Content box.
    • Click Save to add the folder.
NOTE: You can also use a naming macro to assign a new name to the job log by selecting one from the drop-down list. To do this, click the Insert Macro icon naming macros.zoom80 and select the desired macro.
  1. Select one of the following Apply Disposition By Job Status settings:
    • Completed: Select this check box, if you want the specified disposition to occur when a job is successfully completed. Use the adjacent fields to specify the number of days and/or hours after the job is completed that you want the disposition to occur.
    • Failed: Select this check box, if you want the specified disposition to occur when a job fails to run successfully. Use the adjacent fields to specify the number of days and/or hours after the job fails that you want the disposition to occur.
    • Cancelled: Select this check box, if you want the specified disposition to occur when a job is cancelled. Use the adjacent fields to specify the number of days and/or hours after the job is cancelled that you want the disposition to occur.
  2. Click the Save button to save current settings and close the dialog.
© 2024 Altair Engineering Inc. All Rights Reserved.
