Automator User
The Automator User has the right to manage the following components.
Automator
Standard Processes
Processes: The user can add a new Standard Process and edit, delete, and run Standard Processes that are assigned to him.
Schedules: The user can edit, delete, and run schedules whose Standard Processes are assigned to him.
Jobs: The user can edit, delete, and run the jobs whose Standard Processes are assigned to him.
Project Editor: The user can create project files and edit, lock, or delete the project files assigned to him.
Visual Processes
Processes: The user can add a new Visual Process and edit, delete, and run Visual Processes that are assigned to him.
Schedules: The user can edit, delete, and run schedules whose Visual Processes are assigned to him.
Templates: The user can add, edit, and delete templates assigned to him.
Logs: The user can edit, delete, and run the logs whose Visual Processes are assigned to him.
Connection Definition: The user can add, edit and delete connection definitions.
Server Library: The user can add folders, projects, models, workspaces, and change lists to the system and edit, lock, or delete those that are assigned to him. The user can also perform bulk edits on the text content of models, projects, workspaces, change lists, Visual Processes, and Standard Processes that are available to him.
