Copying Data from a Second Copy Volume to a First Copy Volume
Sometimes you need to copy data from a Second Copy volume to a First Copy volume. You can configure a maintenance task to perform this operation in MSAdmin.
To copy data from Second Copy to First Copy volume
On the Navigation Tree, click Report Warehouse, then click Maintenance and select Maintenance Tasks.
Click on the Maintenance Tasks page. The Maintenance Task page appears.
Configure a maintenance task, making sure to select the Copy 2 to 1 option from the Task Type drop-down list.
Click Save.
On the Navigation Tree, click Report Warehouse, then click Maintenance and select Maintenance Processes.
Click on the Maintenance Processes page. The Maintenance Process page appears.
Configure a maintenance process, making sure to assign the maintenance task you just created to it.
Schedule the process to run, or run it manually by clicking Run Now on the Maintenance Process page.
When the process is executed, the maintenance task runs and the data is copied from the Second Copy volume to the First Copy volume.
