Changing DTA Indices
The Change DTA_indices maintenance task allows to change indexes for a premining model.
To change indices
On the Navigation Tree, click Report Warehouse, then click Maintenance and select Maintenance Tasks.
Click
on the Maintenance Tasks page. The Maintenance Task page appears.
Configure a maintenance task, making sure to select the Change DTA_indices option from the Task Type drop-down list.
Click Save.
On the Navigation Tree, click Report Warehouse, then click Maintenance and select Maintenance Processes.
Click
on the Maintenance Processes page. The Maintenance Process page appears.
Configure a maintenance process, making sure to assign the maintenance task you just created to it.
Schedule the process to run, or run it manually by clicking Run Now on the Maintenance Process page.
When the process is executed, the maintenance task runs and the indexes for the pre-mining model are changed.
