Adding a Distribution
To create a Global Distribution
On the Navigation Tree, click Automator > Standard Processes and select Distributions.
Click the Add icon
to display the Distribution page.
In the Location box select the location type from the drop-down list.
NOTE: If the required server is not on the list, refer to Locations Management topic to add a new location. In case of a single server configuration refer to the Configurator Guide in the Monarch Server Installation Guide to change location settings.
In the Path box enter the path to a file or click the Browse button, to select a file. The Named Paths window will appear.
In the displayed window do one of the following:-
From the Named Paths list, select the appropriate named path and select the file from the list of displayed in the Named Path Content box. Click Save to add the file.
In the Path field, type the path to the file. Click Save to add the file.
Click Add Actions to add actions to the distribution.
