Schedules
All schedules for Visual Processes are listed on the Schedules page. You can use this page to add, edit or delete schedules.
To add a new schedule for a Visual Process
On the Schedules page under Visual Processes, click
. The Schedule page will be displayed.
Select the Suspended check box if you want to suspend the task.
Specify the process to which the schedule will be assigned.
Select the task execution frequency from the following options: One Time, Hourly, Daily, Weekly, Monthly.
Set the time you want the process to run.
Set the start date of the schedule.
Select the appropriate timezone from the drop-down list.
Click the Save button to save the schedule or Run Now to start the task immediately.
NOTE: If the Config service is not available and you are using Altair licensing, Automator processes will be switched to "Limp Mode." In this mode, you can run only one process (i.e., one Standard Process and one Visual Process) every hour. Moreover, you cannot run a Visual Process that involves other Standard or Visual Processes. Limp Mode is deactivated once the Config service becomes available.
To edit a schedule for a Visual Process
Click the name of the schedule you want to change or select the schedule by clicking anywhere on the row, and then click
On the displayed page, make the necessary changes and save the schedule.
For details about how to change the schedule settings please refer to Adding a Schedule.
To delete a schedule for a Visual Process
Click
at the end of the row of the schedule you want to delete. A dialog box appears.
Click Delete to remove the schedule from the list.
