Enabling/Disabling Monitoring of Visual Processes
You can enable or disable the monitoring of multiple Visual Processes simultaneously.
To enable/disable process monitoring
  1. On the Navigation Tree, click Automator, and select Visual Processes.
  2. Select the Visual Processes you want to enable/disable the monitoring for by clicking their corresponding checkboxes.
  3. Click the drop-down arrow , and choose Disable Monitoring or Enable Monitoring.
  4. In the Monitoring dialog box, click Ok to proceed.
NOTE: When enabling/disabling monitoring, the changes take effect after approximately 1 minute.
© 2024 Altair Engineering Inc. All Rights Reserved.
