Enabling/Disabling Monitoring of Standard Processes
You can enable or disable the monitoring of multiple Standard Processes simultaneously.
To enable/disable process monitoring
On the Navigation Tree, click Automator, and select Standard Processes.
Select the Standard Processes you want to enable/disable the monitoring for by clicking their corresponding checkboxes.
Click the drop-down arrow , and choose Disable Monitoring or Enable Monitoring.
In the Monitoring dialog box, click Ok to proceed.
NOTE: When enabling/disabling monitoring, the changes take effect after approximately 1 minute.
