Editing a Visual Process
Once you have configured and saved a Visual Process, you can edit it at any time.
To edit a process
On the Navigation Tree, click Automator and select Visual Processes.
Click the name of the process you want to change or clicking anywhere on its row, and then click . You can then modify the process from the Visual Process Designer interface.
NOTE: When loading a Visual Process containing a workspace element, workspace validation is initiated and is terminated automatically after a certain number of seconds. The duration of workspace validation can be modified in Automator's General Settings.
You may terminate the workspace validation manually by clicking Cancel in the loading screen.
