Deleting a Visual Process
You can delete any process on the Processes page.
To delete a process
On the Navigation Tree, click Automator and select Visual Processes.
Click
at the end of the row with the process you want to delete. A dialog box appears.
Click Delete to remove the process from the list.
The process is removed from the Processes page, and its associated logs are removed from the Logs page.
NOTE: When deleting a visual process that uses a model, workspace, or change list in the Server Library, a dialog box appears and gives the option to Delete dependencies. Clicking the Delete dependencies button removes the associated model, workspace, or change list from the Server Library. Clicking Cancel deletes the process only and not the associated model, workspace, or change list. The Delete dependencies option is not available when the model, workspace, or change list is used by more than one process.
