Configuring Logging Settings
Log files for License Manager are typically located in C:\Users\Administrator\AppData\Local\Temp.
To modify the location of log files and the amount of information found in these files, click Settings on the upper right-hand corner of the License Manager and then select the Logging tab.
The contents of the Logging tab display.
Using the drop-down provided, select a logging level using the following table as a guide:
Value
Off
Logs no events.
Error
Logs all exceptions.
Warning
Logs events that have occurred or may occur and cause an otherwise normally running application to malfunction.
Information
Logs events indicating successful application execution regardless of whether the application is working properly or not.
Verbose
Logs low-level events for both user code and servicing
Used for debugging purposes
You can also select a new folder in which to store log files by clicking on the Browse button. Doing so launches a Select Folder dialog that you can use to specify a new log file location.
