Maximum Number of Key and Item Fields in a Summary Definition
Monarch Classic allows a maximum of 30 key fields and item fields combined. When you reach this limit, Monarch Classic will not allow you to add additional key fields or item fields to the summary definition. To include a new key or item field, you must first remove a key or item field from the summary definition.
