Monarch Classic Technical Specifications
Input and Export
Item |
Specification |
Inputs |
Report Files
Database Import Formats
Web
Number of report files opened simultaneously |
1024 |
Input file size |
Limited only by system resources. |
Input line length |
4000 characters |
Input pages |
Export file formats and capacities (per table) |
Report Window
Item |
Specification |
Template size |
256 lines of 4000 characters. |
Currency symbols |
£ (Pound) |
Number formats |
U.S. and International. |
Dates recognized |
Years 1601 to 2400 (when year is expressed as YYYY), 1900 to 2098 (when expressed as 2 digits). |
Date formats |
MDY, DMY, YMD |
Multi-column regions supported |
100 |
Table Window
Item |
Specification |
Size of temporary files used to build table/sort |
Variable depending on number of fields in the table. May total |
Fields in table |
256 maximum for Excel and other file types; 512 maximum for CSV files |
Field name length |
62 characters |
Character field length |
255 characters |
Memo field length |
65536 characters |
Numeric field length |
17 characters (15 significant digits, a negation sign and a |
Date field length |
8 characters |
Records in table |
Variable depending on number of fields in the table, limited to internal database size of 10GB |
Record length |
4000 characters |
Filter, calculated field and sort name length |
31 characters |
Filter and calculated field |
32768 characters |
Find expression length |
127 characters |
Expression nesting |
Unlimited |
Number, and length, of all fields involved in a sort definition. |
The number and length of fields involved in a sort definition is limited only by the capacity of the internal database file underlying a Monarch Classic session and the 512 field overall limit. |
Lookup definitions |
Up to 16 external lookups can be defined. |
Sort definitions |
Limited only by sort key length requirements above. |
Filter definitions |
Limited by512 field capacity of Monarch Classic's internal database. |
Summary Window
Item |
Specification |
Summary name length |
31 characters |
Number, and length, of all fields involved in a summary definition. |
The number and length of fields involved in a summary definition is limited only by the capacity of the internal database file underlying a Monarch Classic session. All sort fields and measures must reside in this file, along with all fields imported or joined from an external database and internal maintenance fields. The maximum capacity of the internal database is 512 fields and 4000 characters. |
Key field length |
256 characters |
Item field length |
256 characters |
Measure length |
14 significant digits each. |
Summary definitions |
Unlimited |
Miscellaneous
Item |
Specification |
Memory requirements |
4GB minimum, 8GB or more recommended for best performance. |
Network compatibility |
All Windows-compatible networks. |
