Supported File Formats
Monarch Classic uses the Jet database engine together with its own internal export engine to export table or summary data to a number of popular file formats. Most applications either use one of the supported formats as their native file format or will import one or more of the supported formats. Monarch Classic determines which file format to use based upon the file extension you provide. The following file formats are supported.
Monarch Classic export engine
Monarch Classic's internal export engine provides the following export capabilities:
Format |
Versions |
Add or replace a table |
Append data to a table |
MS-Excel |
97-2010 |
Yes |
Yes |
Text (UTF-8, UTF-16, ASCII or ANSI) |
N/A |
N/A |
Yes (File) |
Delimited Text (UTF-8, UTF-16, ASCII or ANSI |
N/A |
N/A |
Yes (File) |
Adobe PDF |
1.0 – 1.6 |
N/A |
N/A |
ACE database engine
Monarch Classic uses the Ace database engine to provide the following export capabilities:
Format |
Versions |
MS Access |
3.0,4.0, 2003-2010 |
Yes |
Yes |
dBASE |
III, IV, 5.0 |
No |
Yes |
