Saving a Monarch Classic Session to a Project File
Project files can provide a shortcut by associating a model file with a report file. When you open a project file, Monarch Classic opens the associated report(s) and model automatically.
  1. Make sure that the report and model files you want to associate are currently open. If they are not open, use the Document Explorer to open them.
  2. Select the File tab, then Save As, then Project. The Save Project dialog displays.
  3. Enter a name for the project in the File Name field, then click Save.
    Monarch Classic creates the project file in the designated folder and applies the name you specified to it. The file is saved with a .dprj extension.
© 2025 Altair Engineering Inc. All Rights Reserved.
