Opening Projects and Reports from Altair Monarch Server Library
You can open projects and models from the Altair Monarch Server Library.
To open projects and models in Altair Monarch Server Library, ensure that a server and the correct credentials are specified in the Altair Monarch Server Library Options dialog.
Click File > Open > Project/Model > Altair Monarch Server Library. If more than one server was specified in the Altair Monarch Server Library Options dialog, you will also need to select a server from which to open the object.
The Altair Monarch Server Library Browser displays.
Navigate to the location of the project/model by group (as shown above) or process.
Select the project/model to open and then click Open.
