Monarch 2024 Features
The bullets below highlight some of the newest features and enhancements available in Monarch 2023.
Monarch 2024.1
Monarch Classic Highlights
- Upgrade of Tableau TDE exports to .hyper when opening projects
- Replacement of exports to Tableau TDE and Server with .hyper
- Various bug fixes and UX/UI enhancements
Data Prep Studio Highlights
Import and export support for SAS Transport File Format Version 8 files
Multiselect change operations - Split, Duplicate, Alignment, Extract, Compute
Inclusion of column counts, including hidden and visible columns, in the Prepare window
Support for changing the number of vertical lines in title and grid rows in the Prepare window
PDF Document Options - Expert Engine - Ability to undo/redo alignment changes
Monarch 2024.0
Monarch Server Library browser improvements
AES as the default encryption method for new exports
Dynamic date filtering operation
Alignment editor for PDF reports
Export tables, reports, and summaries to PDF
Implementation of case sensitivity for joins
Implementation of extract text by line number and search term operations
- Preview Data improvements - Updated statistics, inclusion of file information, sort on column information, removal of unhelpful statistics
Application/Workspace settings improvements - Encoding / codepage options for delimited text, report page setup, etc.
Implementation of ability to test credentials for connectors including Splunk, Salesforce, Google Analytics, and IBM Cloudant
Change history item collapsing
Monarch Server integration - Fixed text export, export column mapping
Implementation of Report Index in Report view
Implementation of display width and alignment for columns
Select/Deselect all for split operations
Format column dialog: allow specifying of precision for non-custom formats in which it makes sense
Make fixed precision (F<n>) an option in "Format Column"
Related links
