Keyboard Shortcuts
The following keyboard shortcuts may be used in Altair Monarch Classic.
File
Keyboard Shortcut
Action
ALT + F
Launch the File menu
ALT + F + O + A + O
ALT + F + O + O
ALT + F + O + A + W
ALT + F + O + R + O
ALT + F + O + R + W
ALT + F + O + D + F
ALT + F + O + D + W
ALT + F + O + D + C
ALT + F + O + D + E
ALT + F + O + P + O
ALT + F + O + P + W
ALT + F + O + M+ O
ALT + F + O + M+ W
ALT + F + O + Z + O
ALT + F + O + Z + W
Open all file types (Computer)
Open Recent Documents
Open all file types (Web)
Open Report (Computer)
Open Report (Web)
Open Database (Computer)
Open Database (Web)
Open Database (ODBC
Open Database (OLEDB)
Open Project (Computer)
Open Project (Web)
 Open Model (Computer)
Open Model  (Web)
Open Archive (Computer)
Open Archive (Web)
ALT + F + S
     ALT + F + S + P
     ALT + F + S + M
Save
     Save Project
     Save Model
ALT + F + A
     ALT + F + A + P + O
     ALT + F + A + P + W
     ALT + F + A + P + A
     ALT + F + A + M + O
     ALT + F + A + M + W
     ALT + F + A + M + A
Save as
     Save as Project to Computer
     Save as Project to Web
     Save as Project to Archive
     Save as Model to Computer
     Save as Model to Web
     Save as Model to Archive
ALT + F + G
Page setup
ALT + F + T
     ALT + F + T + P
     ALT + F + T + Q
     ALT + F + T + V
Print
     Print
     Quick Print
     Print Preview
ALT + F + L
Close all
ALT + F + C
     ALT + F + C + R
     ALT + F + C + D
     ALT + F + C + P
     ALT + F + C + M
Close
     Report
     Database
     Project
     Model
ALT + F + H
Help
ALT + F + X
Exit
Home View
Keyboard Shortcut
Action
ALT + H + H
Launch the Home view
ALT + H + N
Open
ALT + H + R
Save
ALT + H + T
Save as
ALT + H + S
Page setup
ALT + H + E
Print
Options
Keyboard Shortcut
Action
ALT + H + N
Launch the Options dialog
ALT + N + A
Accept
ALT + N + C
Close
ALT + N + F
File options
ALT + N + I
Input options
ALT + N + V
View options
ALT + N + E
Export options
ALT + N + L
Clipboard options
ALT + N + S
Security options
ALT + N + T
Time interval options
ALT + N + R
Altair Monarch Server Library
ALT + N + D
Advanced options
ALT + N + M
Theme options
ALT + N + X
Cache
ALT + N + H
Help
Report View
Keyboard Shortcut
Action
ALT + R
Launch the Report view
ALT + R + D
Design
ALT + R + A
Auto Define
ALT + R +  FF
Font style
ALT + R + FS
Font size
ALT + R + Z
Zoom to fit
ALT + R + G
Greenbar
ALT + R + A
Select all
ALT + R + C
Copy
ALT + R + S
Search
ALT + R + F
Find in table
ALT + R + V
Previous report
ALT + R + B
Previous page
ALT + R + T
Go to page
ALT + R + X
Next report
ALT + R + Y
Next page
ALT + R + GC
Go to chunk
ALT + R + O
Bookmark
ALT + R + K
Next bookmark
ALT + R + J
Previous bookmark
ALT + R + L
Clear bookmarks
ALT + R + I
Report Index
ALT + R + II
Open Report Index
ALT + R + IE
Edit Report Index
ALT + R + P
PDF/XPS options
ALT + R + CO
Chunk Options
Report Design View
Keyboard Shortcut
Action
ALT + R + D
Launch the Report Design view
ALT + D + A
Accept
ALT + D + C
Cancel
ALT + D + E
Template name
ALT + D + O
Template role
ALT + D + N
New template
ALT + D + D
Delete template
ALT + D + R
Replace sample text
ALT + D + L
Clearing template
ALT + D + T
Auto-define trap
ALT + D + F
Auto-define fields
ALT + D + M
Multi-column region
ALT + D + V
Run report verify
ALT + D + P
Report colors
ALT + D + H
Help
Table View
Keyboard Shortcut
Action
ALT + T
Launch the Table view
ALT + T + D
Design
ALT + T +  FF
Font style
ALT + T + FS
Font size
ALT + T + Z
Zoom to fit
ALT + T + W
Autosize columns
ALT + T + A
Select all
ALT + T + C
Copy
ALT + T + R
Active filter
ALT + T + T
Active sort
ALT + T + S
Search
ALT + T + G
Go to row or column
ALT + T + F
Find in report
ALT + T + V
Rebuild data view
ALT + T + O
Show field contents
ALT + T + N
Freeze panes
Table Design View
Keyboard Shortcut
Action
ALT + T + D
Launch the Table Design view
ALT + D + A
Accept
ALT + D + C
Cancel
ALT + D + D
Add
ALT + D + Q
Duplicate
ALT + D + T
Delete
ALT + D + B
Database
ALT + D + X
External lookups
ALT + D + E
Field list
ALT + D + I
Input fields
ALT + D + M
Formula fields
ALT + D + L
Lookup fields
ALT + D + R
Runtime parameter fields
ALT + D + U
User edit fields
ALT + D + F
Filters
ALT + D + S
Sorts
ALT + D + K
Address blocks
ALT + D + N
Functions
ALT + D + H
Help
Summary View
Keyboard Shortcut
Action
ALT + S
Launch the Summary view
ALT + S + D
Design
ALT + S + FF
Font style
ALT + S + FS
Font size
ALT + S + Z
Zoom to fit
ALT + S + L
Autosize columns
ALT + S + A
Select all
ALT + S + C
Copy
ALT + S + S
Search
ALT + S + G
Go to row or column
ALT + S + F
Find in table
ALT + S + V
Active measure
ALT + S + U
Drill up
ALT + S + W
Drill down
ALT + S + N
Freeze panes
Summary Design View
Keyboard Shortcut
Action
ALT + S + D
Launch the Summary Design view
ALT + D + A
Accept
ALT + D + C
Cancel
ALT + D + S
Add summary
ALT + D + X
Duplicate summary
ALT + D + D
Delete summary
ALT + D + F
Definition
ALT + D + R
Add/remove fields
ALT + D + L
All fields
ALT + D + K
Keys
ALT + D + I
Items
ALT + D + M
Measures
ALT + D + P
Page setup
ALT + D + H
Help
Export View
Keyboard Shortcut
Action
ALT + E
Launch the Export view
ALT + E + D
Design
ALT + E + A
Select all exports
ALT + E + S
Clear selected jobs
ALT + E + C
Clear job list
ALT + E + E
Create export
ALT + E + R
Run exports
Export Design View
Keyboard Shortcut
Action
ALT + E + D
Launch the Export Design view
ALT + D + A
Accept
ALT + D + C
Cancel
ALT + D + E
Add export
ALT + D + X
Duplicate export
ALT + D + D
Delete export
ALT + D + H
Help
Miscellaneous Shortcuts
Keyboard Shortcut
Action
CTRL + F5
Find in Report/Table
CTRL + J
Save project
CTRL + O
Open model
CTRL + D
Close model
CTRL + S
Save model
CTRL + A
Save model as
CTRL + P
Print
CTRL + HOME
Go to the beginning of a report/first cell of a table/summary
CTRL + END
Go to the end of a report/last cell of a table/summary
ALT + F4
Close
F1
Help
CTRL + TAB
Window cycle through (active) Report, Table, and Summary views
CTRL + X
Text box field - Cut
CTRL + C
Text box field - Copy
CTRL + V
Text box field - Paste
CTRL + A
Select all
CTRL + Z
Undo
CTRL + Y
Redo
© 2025 Altair Engineering Inc. All Rights Reserved.
