Table window
A Monarch Classic window that displays data extracted from a report file, database source, external lookups, or a combination of sources, assembled as database records. In this window, you can look up information from the table, sort and filter it, create calculated fields, print tables, export them, and copy selected sections to other applications via the Clipboard.
