Function: Replace
Replaces within a given string each instance of a specified substring with a new substring.
Replace(string,old,new)
Note: Replacements are case-sensitive. If old is empty then no replacements are made. If new is empty, then instances of old are effectively removed from the string.
Arguments
string is the string that contains the substring you want to replace.
old is the substring to be replaced.
new is the substring to replace old.
Return value
This function returns a character string.
Calculated field example
If a Contact field contained Mary Smith, the following calculated field expression would return Mary Smith-Jones:
Replace(Contact,"Smith","Smith-Jones")
Filter/Find example
Records with a Contact field value of Mary Smith-Jones could be found by the expression:
Replace(Contact,"Smith","Smith-Jones")="Mary Smith-Jones"
© 2025 Altair Engineering Inc. All Rights Reserved.
