Function: RegexIsMatch
Scans the given string for a match to the given regular expression pattern.
RegexIsMatch(string,pattern)
Arguments
string refers to the input text.
pattern refers to the regex pattern to match.
Return value
Returns 1 if a match is found, 0 otherwise.
The expression RegexIsMatch([Department],"[A-Z]{1}[a-z]{3}\s") results in a value of 1 when this field contains the entry "Data Processing."
© 2025 Altair Engineering Inc. All Rights Reserved.
